TwinTurbo.NET: Nissan 300ZX forum - Ecu check first, then ohm test injectors
yobobrox
on June 13, 2008 at 1:23 PM
Rough Idle and no power
posted by Timmy
on June 13, 2008 at 01:08 PM
With all the ethanol circulating now, injectors are dropping like flies.
Timmy
13:08:39 06/13/08
Also plenty of oil and coolant is fine (n/m)
Timmy
13:18:55 06/13/08
Ecu check first, then ohm test injectors -
yobobrox
13:23:31 06/13/08
On the ECU test, the check engine light will blink (n/m)
Timmy
13:37:55 06/13/08
It is supposed to
93DemonCar
14:41:27 06/13/08
Check PTU connections for corrosion... (n/m)
twinturbineZ
18:12:04 06/13/08
Update, car is now working fine? I did nothing to it
Timmy
20:16:17 06/13/08
Probably corroded connectors and intermittent
Audioquest
00:01:26 06/14/08
